I am testing my rs485 communication thru a 60 meters of cable, it seems working at 9600 baud rate. I have one master and one slave.I am using SN75176. I have put 1k resistor between A and B pins. There is a 4,7k from A pin to +5V and 4,7k from B to ground. My maximum communication distance will be about 60 m. Do you think this is the optimal circuit, or what corrections can be done?
I also want to ask, how I can apply noise to this 60 meters cable for test.
Thank you very much.
