RS485 IMPLEMENTATION ON PIC MICO
Discussion in 'Programmer's Corner' started by RRITESH KAKKAR, Apr 14, 2015.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    For serial communication can we use RS485 with multi drop features?
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You can do anything you want to do. The better question is do you understand how to use some kind of protocol to know when you should be talking and when you should be listening? A related question is: do you know how to put together a multidrop cable system?
    RRITESH KAKKAR likes this.
  3. OBW0549
    Mar 2, 2015
    1,389
    932
    Of course you can; that's what RS-485 is for.
    As for implementing RS-485 with a PIC, here's a hint: Googling "RS-485 with PIC" gives over half a million hits.
  4. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I dont know how to this.!
  5. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Is UART Tx and Rx serial communication is similar to this protocol?
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    It will take more than a forum post.
    1. Put termination resistors only at the ends of the cable system. Never put them in a product.
    2. Limit the number of nodes on the cable system.
    3. Measure the transmit voltage levels on a transmitter at one end, and measure them again on the other end. How much degradation has there been?
    4. As you go to higher baudrates, beware of reflections
    5. Keep the droplines short
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Yes, except that it can be half-duplex. What that means is that you cannot transmit and receive at the same time. You might also have to manage a TRANSMIT ENABLE signal on your transceiver. The framing and the asynchronous nature of the character transmission is just the same as RS-232.
  8. OBW0549
    Mar 2, 2015
    1,389
    932
