I am using a board with wired communication on RS485. I am using SN65HVD72, it specifies cable length to be 2000m.
The board on other side which is in field, i.e 30m away has 4 wire connection, i.e Vcc, Gnd, A, B. (where A, B are RS485 signals).
1. I am planning to use four core cable.
2. My field board has 80mA current consumption. Vcc is +5V. This +5V goes to 3.3V regulator which is used for board finally.
Question:
1. Will +5V be able to show at filed board which is 30m away from centeral board. Also keeping in mind 80mA cuurent consumption.
2. Will RS485 will be done fine?
3. What type of four core cable I should select
Question:
