Dear All
I am going a bit cross eyed with determining if my circuit will work as planned. You input is needed to set me right.
The circuit purpose is to take an RS232 input and output and level convert/invert to 3.3V TTL serial. On the TTL side there are two devices: one is a bluetooth device for transmitting the data. And the the second a Microchip MCU to listen and sometime interrupt communication to sent status data - as such is priority.
The uartRX constantly listens to the bluetooth received data. When the MCU wants to transmit it actuates CommsEN to close off the transmitted data to H1 and then outputs TTL data to the bluetooth TX.
I am unsure on the impedances on the TTL BT and uart pins or the rules used to govern these kind of connections - i.e. TX drives the line idle high.
Cheers
Alex
Cheers
Alex
