RS232 testbench
Discussion in 'Embedded Systems and Microcontrollers' started by domino89, May 15, 2014.
  1. domino89
    Sep 24, 2013
    22
    I have wierd problem with RS232 implementation it works on board but dunno whats wrong with testbench it just doesnt work. Could somone take a look on this testbench code...
    Code ( (Unknown Language)):
    1. `timescale 1ns
    2.
    3. module testbench;
    4.
    5.     // Inputs
    6.     reg RXD_i;
    7.     reg clk_i;
    8.
    9.     // Outputs
    10.     wire TXD_o;
    11.
    12.     // Instantiate the Unit Under Test (UUT)
    13.     main uut (
    14.         .RXD_i(RXD_i),
    15.         .clk_i(clk_i),
    16.         .TXD_o(TXD_o)
    17.     );
    18.
    19.     initial
    20.     begin
    21.         // Initialize Inputs
    22.     clk_i=0;
    23.     RXD_i=1'b1;
    24.
    25.     #100 RXD_i=0;
    26.     #10 RXD_i=0;
    27.     #10 RXD_i=1;
    28.     #10 RXD_i=0;
    29.     #10 RXD_i=1;
    30.     #10 RXD_i=1;
    31.     #10 RXD_i=1;
    32.     #10 RXD_i=0;
    33.     #10 RXD_i=1;
    34.     #10 RXD_i=0;
    35.         end
    36.
    37.         always
    38.         #5 clk_i =~clk_i;
    39. endmodule
    And I get on TxD_o "1" for whole simulation
  2. Brownout
    Jan 10, 2012
    2,375
    998
    What do you expect to get?
  3. domino89
    Sep 24, 2013
    22
    It sends what it gets on input.
  4. Brownout
    Jan 10, 2012
    2,375
    998
    Since I don't know how the UUT is coded, I cannot verify your expected results. If it use a UART, you need to write something to the TX buffer.
  5. domino89
    Sep 24, 2013
    22
    This rs232 code which i was testing. This version transmitts what it receives. Parameter N is reduced for testbench purpose. As a said before wierd thing is that it works on board with hyperterminal, but i struggle with this testbench
    1.
    2. ********************************
    3. *******MAIN MODULE***************
    4. ********************************
    5. `timescale 1ns / 1ps
    6.
    7. module main (RXD_i, clk_i, TXD_o
    8.     );
    9.
    10. input RXD_i, clk_i;
    11. output TXD_o;
    12. wire [9:0]receive;
    13.
    14. receiver A(RXD_i, receive, clk_i, save);
    15. transmitter B(TXD_o, receive, clk_i, save);
    16.
    17. endmodule
    18.
    19. ********************************
    20. *******RECEIVER MODULE***********
    21. ********************************
    22.
    23. `timescale 1ns / 1ps
    24.
    25. module receiver (RXD_i, receive, clk_i, save);
    26.
    27. input RXD_i, clk_i;
    28. output reg [9:0]receive, save=0;
    29. integer div1=0, bits_counter1=0, start1=0;
    30. reg [9:0]send;
    31. parameter N = 2; //5208
    32.
    33. always @(posedge clk_i)
    34. begin
    35. save=0;
    36. if(start1==0)
    37. begin
    38.     receive[0]=1'b1;
    39.     receive[1]=1'b1;
    40.     receive[2]=1'b1;
    41.     receive[3]=1'b1;
    42.     receive[4]=1'b1;
    43.     receive[5]=1'b1;
    44.     receive[6]=1'b1;
    45.     receive[7]=1'b1;
    46.     receive[8]=1'b1;
    47.     receive[9]=1'b1;
    48.     end
    49.
    50. if(RXD_i==1'b0 && start1==0)
    51. start1=1;
    52.
    53. if(start1==1)
    54. begin
    55.     if(div1==N)
    56.     div1=0;
    57.     else if(div1==N/2)
    58.     begin
    59.     div1=div1+1;
    60.     bits_counter1=bits_counter1+1;
    61.     case(bits_counter1)
    62.     0   :   receive[0]=RXD_i;
    63.     1   :   receive[1]=RXD_i;
    64.     2   :   receive[2]=RXD_i;
    65.     3   :   receive[3]=RXD_i;
    66.     4   :   receive[4]=RXD_i;
    67.     5   :   receive[5]=RXD_i;
    68.     6   :   receive[6]=RXD_i;
    69.     7   :   receive[7]=RXD_i;
    70.     8   :   receive[8]=RXD_i;
    71.     9   :   receive[9]=RXD_i;
    72.     endcase
    73.     end
    74.     else
    75.     div1=div1+1;
    76.
    77.     if(bits_counter1>9)
    78.     begin
    79.     save=1;
    80.     start1=0;
    81.     bits_counter1=0;
    82.     div1=0;
    83.     end
    84.     end
    85.     end
    86. endmodule
    87.
    88. ********************************
    89. *******TRANSMITTER MODULE********
    90. ********************************
    91.
    92. `timescale 1ns / 1ps
    93.
    94. module transmitter (TXD_o, receive, clk_i, save);
    95.
    96. input [9:0]receive, clk_i, save=0;
    97. output reg TXD_o;
    98. integer div=0, bits=0, start=0;
    99. reg [9:0]send;
    100. parameter N = 2; //5208
    101.
    102. always @(posedge clk_i)
    103. begin
    104. if(save==1)
    105. begin
    106. send<=receive;
    107. start=1;
    108. end
    109. if(start==1)
    110. begin
    111.     if(div==N)
    112.         div=0;
    113.     else if(div==N/2)
    114.     begin
    115.     div=div+1;
    116.     bits=bits+1;
    117.         case(bits)
    118.     0   :   TXD_o<=send[0];
    119.     1   :   TXD_o<=send[1];
    120.     2   :   TXD_o<=send[2];
    121.     3   :   TXD_o<=send[3];
    122.     4   :   TXD_o<=send[4];
    123.     5   :   TXD_o<=send[5];
    124.     6   :   TXD_o<=send[6];
    125.     7   :   TXD_o<=send[7];
    126.     8   :   TXD_o<=send[8];
    127.     9   :   TXD_o<=send[9];
    128.     endcase
    129.     end
    130.     else
    131.     div=div+1;
    132.
    133.     if(bits>9)
    134.     begin
    135.     bits=0;
    136.     start=0;
    137.     div=0;
    138.     end
    139.     end
    140.     else if(start==0)
    141.     TXD_o<=1'b1;
    142.     end
    143. endmodule
    144.
    145.
  6. Brownout
    Jan 10, 2012
    2,375
    998
    I would start by fixing all the "start1" statements. eg:
    1.
    2.
    3.  start1 1=0;
    4.
    After that, start a wave window and begin looking at waveforms. That's how debug gets done.
  7. domino89
    Sep 24, 2013
    22
    OH sry i didint notice I have posted version with this bug... Ofc all "start1 1" was replaced with start1.
  8. Brownout
    Jan 10, 2012
    2,375
    998
    Look at start1 with a wave viewer and see what it's doing.
  9. domino89
    Sep 24, 2013
    22
    It works... I had an error in testbench clk declaration (forget that #5 refers to time of low/high time not a period of clock)
  10. Brownout
    Jan 10, 2012
    2,375
    998
    Glad you got it to work. You might try something like this for your testbench code in the future:
    1.
    2.  ....
    3.
    4.  always
    5.  #5 clk <= ~clk;
    6.
    7.  initial begin
    8.  wire [0:15] RXD_BUFF = 16'b101010.....;
    9.  integer i = 0;
    10.  end
    11.
    12.  always @posedge(clk) begin
    13.     if(i<16)
    14.      RXD <= RXD_BUFF[i];
    15.  end
    16.  ....
    17.  [/i]
  11. domino89
    Sep 24, 2013
    22
    Thanks for help
