RS232 signal to BCD converter
Discussion in 'General Electronics Chat' started by mrs.latagupta, Jun 22, 2009.
  1. mrs.latagupta
    Mar 25, 2009
    I need to know how to convert RS232 signal into BCD format ?
  2. mauro.laurenti
    May 8, 2009
    68
    ...is not the right question.
    Think what RS232 is.
    Think what BCD is.
    Think what you need.
    Ciao,
    Mauro
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Actually your question seems like a reasonable one to me.
    Since you are dealing with an 8-bit binary value received over your RS-232 link then you can predict what the range of BCD numbers you will need to be able to support. The smallest value is 0 and the largest value is 255.
    Before I divulge any more information it would be nice to know if this question is part of a class assignment?
    hgmjr
  4. mauro.laurenti
    May 8, 2009
    68
    The RS232 is a protocol, which describes hardware (mechanical and electrical specifications). The BCD is a data format.
    It is possible from the question understand what he meant and make assumptions.
    The RS232 supports 6, 7, 8 bits...which create more assumptions.
    Ciao,
    Mauro
