I am doing a project and need to communicate between an application
on computer with PLC through RS232 port.
The app send "1" or "0" to PLC. However, sometimes PLC doesn't receive
that. To check what is happening I used AccessPort to monitor.
I am not at work right now, so I can't have the log file but it is
something like the one below.
As you can see in the line #34, the "Result" is nothing and "Time" is 0.00000000.
However, "Data" is still OK ("1" in this case).
Where is the problem in this case?
Is that the app sending is OK because "Data" from the AccessPort is still OK.
The problem is that this data doesn't come to PLC.
Code:
# Time Process Request Port Result Other
33 0.00002222 app.exe IRP_MJ_WRITE Serial0 SUCCESS Data: 1
34 0.00000000 app.exe IRP_MJ_WRITE Serial0 Data: 1
35 0.00000562 app.exe IRP_MJ_READ Serial0 SUCCESS Data: 0
36 0.00000239 app.exe IRP_MJ_READ Serial0 SUCCESS Data: 0
