RS232 and ESD
Discussion in 'General Electronics Chat' started by happyfpga, Mar 7, 2009.
  1. happyfpga
    Oct 4, 2008
    7
    Hi everyone, we are building a equipment powered by batteries. It has RS232 interface. When we plug/unplug rs232 cable (connecting to PC on another end) with the equipment on, the MCU inside the equipment sometimes crashed. I observed the 5V power line inside the equipment, high voltage spike can be caputred by the scope. I think it is caused by the different ground between the equipment and the PC.
    Any idea to prevent such kind failure? The rs232 transceiver inside the equipment has ESD protection function.
    Thanks for any suggestion.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Have you read the AAC book chapter on ESD?
    http://www.allaboutcircuits.com/vol_3/chpt_9/1.html
    From what I'm hearing it might not be ESD, more of a power supply surge charging the internal capacitors.
    If it is ESD, if you can create ground on both pieces of equipment, preferably a third point, to equalize the charge before plugging cable in.
