RS-422 chip questions
ghall426
Joined Jul 22, 2009
11
I am building a circuit using the AM26C32 quad receiver, however I am only using 3 of the 4 lines. My questions are:
1. Do I need to do anything with the A & B differential inputs that I'm not using to keep them from floating to stop any potential oscillations?
2. Do the driver and receiver need to share a common ground, or are the differential pairs all that is needed between the 2 chips?
30,821
AM26C32 inputs are already pulled up or down. You can leave them not connected.
RS-422 and RS-485 systems would normally be grounded via chassis or earth ground.
No, you do not need an extra ground connection if both ends have good ground connections.
ghall426
Joined Jul 22, 2009
11
Thanks for the replies. One more question:
I've seen on other RS-422 receiver chips that a 100-ohm resistor is required between the differential inputs. The AM26C32 datasheet doesn't mention this, so is it still required?
If so, why does it have to be an external resistor? Why can't they take care of this internally?
Sensacell
Joined Jun 19, 2012
3,451
The 100 ohm resistor is a line terminator to match the impedance of the cable, preventing signal reflections.
It should be the same resistance as the cable impedance.
If you have a multi-drop network, the mid-cable nodes typically do not have a terminating resistor.
