Sorry about thatContinue on the original thread please. Both multiple threads on the same subject and calling out specific forum members is rude behavior. People will help when they are able.
I don't recall mentioning a part number, can you direct me to the OP where I suggested it?Thanks Max , if you recall this one was recommended by you so I ordered it, so I'm just wondering if I could get some help hooking it up? The 3 wires coming from the sensor are one thing, but the wafer cable is bothering me, it plugs Into the display but I don't know where the other end goes? Reminder that I'm very new to all of this
After using different makes and manuf, there definitely seems to be an agreed pattern, where this originated from, I cannot say.Max,
That seems like an odd color assignment yet you talk like it is some defacto industry standard. Is there some sort of history to that.
When it comes to inductive sensors, there's no real industry standard, and wiring color can change from brand to brand. However, the dominant models are usually German (and Chinese) and those are the standard colors that they've been using for years.Max,
That seems like an odd color assignment yet you talk like it is some defacto industry standard. Is there some sort of history to that. Is there some sort of decoder chart that has all the wire color assignments for common sensors?
You found it on eBay and sent me he link, it's from China. I asked for help to find a RPM sensor to measure the speed on my lathe. My original post that you and Dave helped me with was for wiring motors to make a power feed for my lathe.I don't recall mentioning a part number, can you direct me to the OP where I suggested it?
IIRC it was a counter?
I may have just recommended a proximity sensor, remind me what you are hooking into.
Max.
The makes I have used in the past that also conform include Idec, Balluff, Omron, Allen-Bradley, Turk et-al.When it comes to inductive sensors, there's no real industry standard, and wiring color can change from brand to brand. However, the dominant models are usually German (and Chinese) and those are the standard colors that they've been using for years.
Well, my question here is, which type of sensor is he using, NPN or PNP? Because if it's a PNP, most likely it works at around 12VDC (normal sensors work in the range of 10 to 30VDC) and its output will also be 12VDC, and if it's directly connected to the PCB without at least a voltage divider, it will fry the 5V MCU.His next question will be, "which terminal does the sensor output connect to, CS or IN"...
I very much doubt that what we're seeing is a hall-effect sensor... but you never know. In any event, it's very is for the OP to test if the disc is a magnet or not.It is NPN the display and prox was bought as a set off ebay.
I am wondering if it is going to also sense ferrous metal, as the ebay demo shows mounted on a Plexiglass wheel with the disc magnet attached.
That is presuming it IS a magnet?
Max.
Evidently it is!I very much doubt that what we're seeing is a hall-effect sensor... .
I'm afraid you've lost me, Max. Your link says that the sensor is of the inductive type, but that a magnet is included. Now, I've used inductive sensors before and they also work on aluminum and even copper, though with less sensitivity.
I don't see the connection??http://gallery.trailtech.net/media/instructions/computers/vapor/010-ELV-07.pdf
Check this. It may help you.
