Are you certain that wafer is not a magnet? Seems a bit thin for one but who knows. Place a paper clip on it to see if it sticks.Just got this in the mail finally and it's not what I thought!!? The wafer cable needs to be wired but I have no idea to what. I also don't know where the 3rd wire from the sensor goes, can someone help this major newbie with 2 year old language?
lol my wife did that to a piece of tape on my work benchHey, Major! Were you the artist or was that someone else you speak to in 2-year-old language.
the wafer cable plugs into the digital display, but I don't know where the other ends go!Are you certain that wafer is not a magnet? Seems a bit thin for one but who knows. Place a paper clip on it to see if it sticks.
Why don't you continue on your original tread?well the rpm sensor finally came, but im very confused about how to wire it, are one you guys out there?
help!View attachment 95797
I was hoping the 2 members that were originally helping me with this would see the newer post. The idea of naming them on the heading was an afterthought. One of them recommended I buy this sensor so now I need help wiring it.Why don't you continue on your original tread?
Continue on the original thread please. Both multiple threads on the same subject and calling out specific forum members is rude behavior. People will help when they are able.I was hoping the 2 members that were originally helping me with this would see the newer post. The idea of naming them on the heading was an afterthought. One of them recommended I buy this sensor so now I need help wiring it.
Agreed. It looks exactly like that. The device is probably nothing more than a simple frequency counter, which then translates the signal into RPMs. Also, probably the wafer is a metal disc meant to be adhered to a non-ferrous wheel for the sensor to work properly.Appears to be a common proximity ferrous metal detector, the most common (standard) wire colours are Brown=+v, Black=output, Blue=-ve
You also need to know if it is NPN or PNP output, usually open collector.
Max.
Max,Appears to be a common proximity ferrous metal detector, the most common (standard) wire colours are Brown=+v, Black=output, Blue=-ve
Max.
Thanks Max , if you recall this one was recommended by you so I ordered it, so I'm just wondering if I could get some help hooking it up? The 3 wires coming from the sensor are one thing, but the wafer cable is bothering me, it plugs Into the display but I don't know where the other end goes? Reminder that I'm very new to all of thisAppears to be a common proximity ferrous metal detector, the most common (standard) wire colours are Brown=+v, Black=output, Blue=-ve
Max.
