RP-TNC Female to Female?
Discussion in 'General Electronics Chat' started by Robert.Adams, Apr 21, 2010.
  1. Robert.Adams
    Thread Starter Active Member
    Feb 16, 2010
    112
    5
    I have recently acquired a ThingMagic Mercury4 RFID reader and a pair of M/A-COM 902-928 MHz North American RFID antennas.
    I do not however have a connector for the reader to the antennas. It seems I need a female RP-TNC to female RP-TNC connector, but I'm not sure. I can not seem to find this configuration on ebay.
    Can anyone help me?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  3. Robert.Adams
    Feb 16, 2010
    112
    5
    I did notice those, but they won't be enough for my setup. The reader and the antenna are big and require at least some distance to separate them.
    I could get the cables and adapters, but I was looking for cables that would make the adapter unnecessary.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, if that's not going to do it for you, then either have Pomona Electronics make up some cables to your specifications, or you could go over to Mouser.com and buy some TNC to SMA adapters, some SMA to semirigid coax connectors and some semirigid coax, and make up whatever length you need.
  5. retched
    Dec 5, 2009
    5,201
    313
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Retched,
    That's RP TNC one end, but N on the other. He needs RP TNC both ends.
    Another way to go might be to get a couple of RP TNC to BNC adapters, and just use standard BNC test cables between the two. More loss than using the TNC to SMA and semirigid, but no fabrication involved.
  7. retched
    Dec 5, 2009
    5,201
    313
    My bad. What I was trying to get at was he could use a male - female cable and adapt the male end usind the f-f adapter.
