Routh-Hurwitz Theorem
Discussion in 'Homework Help' started by Zaryab Saeed, Mar 20, 2016.
  1. Zaryab Saeed
    Feb 10, 2016
    Hi, I have a problem in which, given a polynomial, I have to calculate the number of roots with positive, zero and/or negative real parts. Now I know that every sign change in the first column of the Routh array indicates the number of roots with a positive real part, but how do I find out the roots with negative and/or zero real parts? I've tried reading up on it, but couldn't find the answer to this anywhere. Any help would be appreciated. Thanks!
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    1. You can graph the polynomial.
    2. You can use synthetic division to search for x-axis intersections, then use Newton's method to refine the result.
    3. Roots with a zero real part are actually conjugate pairs.
    4. Use the quadratic formula after finding one or more real roots.
    5. Ask Matlab, Scilab, or Octave to give you the roots.
  3. MrAl
    Distinguished Member
    Jun 17, 2014
    2,553
    515
    Do you have to use R.H. or can you use any method you choose?
    Also:
    I think a better wording for #3 is: "Roots with an imaginary part appear as conjugate pairs".
    They can have a non zero or zero real part.
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Yes they can, but the answer was a response to the context of the original question.
  5. MrAl
    Jun 17, 2014
    2,553
    515
    Yes, very good. I was being a bit more general with my reply.
