routers
Discussion in 'Computing and Networks' started by waynejhez, Jul 1, 2013.
  1. waynejhez
    Jun 26, 2013
    Hi guys! I have two different old routers a linksys wrt 54g and netgear adsl modem wireless router DG834PN. I just wanna ask if i can use the two old routers link each other wirelessly using bridge connection creating a wireless internet access?
    Thank you..
  2. studiot
    Nov 9, 2007
    5,005
    515
    I don't think those two can be configured to work that way.
  3. electronis whiz
    Jul 29, 2010
    519
    27
    I don't think you can because their not meant to act like that. some enterprise class wifi access points can do that though. you may want to try ddwrt it is an open source router firmware that you can flash onto many routers.
  4. waynejhez
    Jun 26, 2013
    thank you for the reply,, i searching about dd-wrt firmware i found out, that it has a supported list of routers that can be compatible with this firmware. unfortunately my router doesn't exist on that list..:( so i gonna buy a new ones..
    another question, if your going to setup a wireless bridge connection into a router, is that supposed to be the same unit and model? and how many routers i need to setup for a wireless bridge connection?
    thank you..
  5. studiot
    Nov 9, 2007
    5,005
    515
    Before you spend any money, please explain exactly what you are trying to do - in detail.
    Answers here may save you a packet.
  6. Ramussons
    May 3, 2013
    561
    92
    I think he wants to use 1 modem as a WAP and the other as a wifi interface to a smart tv :D
    Ramesh
  7. waynejhez
    Jun 26, 2013
    I want to setup a wireless bridge or a wireless repeater..to have a wifi access..
    waynejhez
