Router auto-reset
Discussion in 'The Projects Forum' started by mscreations, Aug 15, 2012.
  1. mscreations
    Dec 14, 2009
    6
    I'm trying to create a device that will reset my router that is hidden in the basement once a day. I am thinking about using some type of 555 circuit to create a 10-20 sec HI pulse that will occur once every 24 hrs. The pulse will activate a reed relay that will temporarily disconnect the power going to the router. I also want to be able to use a switch to create a pulse immediately.
    I've created some timing circuits with a 555 before, but never one that needs to repeat after a set amount of time. I'd rather not have to use a microcontroller to do this if possible.
    I'm planning on powering the device from the line that I'm disconnecting (eg. input power somewhere in range of 5-18v. I have three devices that I want to make modules for. All with different voltages.)
    Any ideas or pages that might be able to give me some pointers?
    Thanks!
  2. wayneh
    Sep 9, 2010
    12,405
    3,256
    Conventional lamp timers would get you going a lot faster and cheaper. You can get them for about $5 with a programmable digital clock and control.
