Rotate a stepper motor?
Discussion in 'Embedded Systems and Microcontrollers' started by donnyjason, Feb 8, 2011.
  1. donnyjason
    Feb 6, 2011
    Hello there,
    I'm still new in programming. I need to know how to program to rotate a stepper motor. Just basic code is enough as I'm totally know nothing although I have read some notes on stepper.
    I would really appreciate for your help. Thanks.
  2. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
  3. mcgyvr
    Oct 15, 2009
    4,791
    976
  4. donnyjason
    Feb 6, 2011
    I have two unipolar stepper motor. Both have 5 pins. I plan to use PIC uC later to control the motor instead of adruino because I have the uC board already.
    Does it answer your question Bertus?
  5. be80be
    Jul 5, 2008
    432
    57
  6. donnyjason
    Feb 6, 2011
    this is the program i have just written. any wrong with it? the motor suppose to rotate only clockwise but then when tested it rotate both way after reset button on uC is pressed.
    LIST P=16F877A
    #INCLUDE <P16F877A.INC>
    __CONFIG 0X3F32
    X1 EQU 0X20
    X2 EQU 0X21
    X3 EQU 0X22
    PORTB equ 0x06
    status equ 0x03
    org 0x00
    goto start
    org 0x06
    start bcf STATUS,RP0
    bcf status,RP0
    CLRF PORTB
    BSF STATUS,RP0
    BCF STATUS,RP1
    movlw B'11110000' ;same as 0xF0, 0 means ouput,1 input motor output
    movwf ADCON1
    CLRF TRISB
    BCF STATUS,RP0
    BCF STATUS,RP1
    CLRF PORTB
    main:
    movlw b'00001010'
    movwf PORTB
    call delay
    movlw b'00001001'
    movwf PORTB
    call delay
    movlw b'00000101'
    movwf PORTB
    call delay
    movlw b'00000110'
    movwf PORTB
    call delay
    goto main
    delay:
    MOVLW D'25'
    MOVWF X3
    B3 MOVLW D'25'
    MOVWF X2
    B2 MOVLW D'25'
    MOVWF X1
    B1 DECFSZ X1
    GOTO B1
    DECFSZ X2
    GOTO B2
    DECFSZ X3
    GOTO B3
    RETURN
    END
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    One very important question - how have you interfaced the stepper with the microprocessor? Simply attaching wires is not going to work.
  8. donnyjason
    Feb 6, 2011
    I connected the motor to the L293D (motor driver) then to the uC board at portb (pb0-pb3). any idea?
  9. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    Why not try boostc instead of asm. Free version should do fine.
    Easy to move back and forth to an Arduino and other processors.
    Many like asm, but many think they are nuts: see http://www.eevblog.com/tag/arduino/
    about 13 minutes in.
