Rotary switch voltage rating?
Discussion in 'General Electronics Chat' started by coinmaster, Apr 2, 2016.
  1. coinmaster
    Dec 24, 2015
    357
    6
    Hi, I need a rotary switch to switch in and out different high voltage circuits.
    The voltages involved are anywhere between -300v and +300v
    I noticed that rotary switches have a voltage rating on them. How can they have a voltage rating when they are effectively a short? There should never be more than 0v between the input and output right?
  2. Alec_t
    Sep 17, 2013
    5,973
    1,135
    But they aren't always a short ;). When the switch is open you don't want arcing or current leakage between contacts.
  3. coinmaster
    Dec 24, 2015
    357
    6
    If I have 2 terminals with a high voltage differential while the switch is closed is there a chance of arc or only when it's open?
  4. ErnieM
    Apr 24, 2011
    7,437
    1,626
    Well you certainly can't get an arc across a short can you?
    For the rotary switch you began asking about you could also get a short between switched lines so with signals of -300 and +300 volts you need 600 volts (minimum!) of isolation rating.
  5. KeepItSimpleStupid
    Mar 4, 2014
    1,276
    224
    one concept you need to be familiar with is "shorting" and "non-shorting". "Shorting" can mean "make before break" and non-shorting is break before make. the shorting switches were used in audio switching.
    DC, AC and RF have all sorts of different requirements. Some high voltage relays can only switch when they are potential free.
    Materials of the switch has certain breakdown voltages or even bulk-resistivity. Humidity can alter that.
    So, a high voltage can arc while your turning a slow switch.
    The voltage and current are just a part of the problem.
  6. coinmaster
    Dec 24, 2015
    357
    6
    Well I don't intend to be turning the switch during operation. What I was asking was is there a risk of arcing if there is high voltage potential between the terminals while the switch is fixed in place? Obviously air resistance is much higher than metal but if the thing can arc at a measly 30volts then who knows what can happen at hundreds of volts.
  7. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Yes. The higher the voltage the wider the gap needed between terminals.
    The switch manufacturer should know.
  8. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    The rating also applies to the insulation value and properties of the switch and the material used.
    Max.
  9. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
    As @MaxHeadRoom said , the isolation of the switch is dependend on the used isolation material.
    You will need to have an isolation voltage of at least 600 Volts, as your voltages can be +300, but also -300 Volts.
    A switch rated 1000 Volts would be safe for your application.
    Bertus
