Rotary Switch Question
Discussion in 'General Electronics Chat' started by oidium45, May 20, 2010.
  1. oidium45
    Thread Starter Active Member
    Apr 24, 2010
    130
    8
    Here is a silly question...
    I am having difficulty choosing/finding a rotary switch for my project. I know nothing about rotary switch terminology... Maybe someone could explain to me what exactly I should be looking for?
    Here is what I need.
    1) It needs to have a minimum of 3-4 positions.
    2) Each position needs to change two seperate connections simultaniously.
    3) It must be rated for 5A or better.
    Would this be a 2 pole/3-4 way switch?
    Maybe someone could explain the difference between pols, positions, and decks?
    Any help will be greatly appriciated.
  2. retched
    Dec 5, 2009
    5,201
    313
  3. retched
    Dec 5, 2009
    5,201
    313
    Poles are the number of pins switched at once,
    positions are the number of selections you can make with the knob
    and decks are actually layers of poles. If you wanted 36 wires to switch in 12 positions 3 poles,
    you could use 3 deck 12 position 3 pole.
    PackratKing and oidium45 like this.
  4. oidium45
    Apr 24, 2010
    130
    8
    thank you retched
  5. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    Look up: make before break and break before make, it can make a difference. On can produce a short, the other an open.
    oidium45 and PackratKing like this.
