1. transistortransistor
    Oct 9, 2013
    11
    Hello everyone,
    I have a question where I need to write which value D3,D2,D1,D0 will have for all possibilities of A3, A2, A1, A0.
    Here is the image:
    This question seems very straightfoward. I just have to check A2 to see which ROM will be enable, then I check the address (A3,A1,A0) then I check what will be in D3,...,D0.
    My question is: what is that "A▼"? And what is that "} A 0/7"? and in what order is the output? is the MSB the one in "A▼"?
    PS: Sorry for my english.
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  3. transistortransistor
    Oct 9, 2013
    11
    Well, so correct me if I'm wrong:
    -> The block on top is a common control block, meaning that it ENABLE signal control all bottom block
    -> The ▼ means Three-State what means that if the block isn't enabled, it will be in high impedance, removing the output of the circuit.
    ->" } A 0/7 " only means grouping the bits meaning that the input group is, in case of binary, a number that you will convert to get the correspondent output.
    But I still have one thing to confirm: let me say I have input 0000. Then ROM A will be active, then output will be 0111. But in the output where will be the MSB bit? is is the most bottom one (going to D3)?
