Rom size?
Discussion in 'General Electronics Chat' started by morgan, Jul 10, 2010.
  1. morgan
    Jul 10, 2010
    9
    I want to realize a combinational logic function that can perform the function of a 74*381 by using a particular size of a ROM. Could anyone tell me what kind of ROM should I use?
  2. tom66
    May 9, 2009
    2,613
    214
    ROM = Read only memory (?)
    How would some ROM realise a logic function?
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    A number in brings a number out. A truth table in other words. Old tech, but it works well.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    A 74381 is a ALU (arithmetic logic unit). It has 12 inputs and 6 outputs. That means it has 2^12 bits X 6, or 4,096 X 6 cells. Seems doable, but a real pain to program.
  5. morgan
    Jul 10, 2010
    9
    Does each ROM need one output or six outputs?
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    I'm thinking there are 4K X 8 ROMs out there, but more than that I can not help with. The X 8 is the data width of a 8 bit word. You are going to also need an EPROM programmer.
  7. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    Bill is right. An 2732 eprom would work.
    http://www.futurlec.com/Memory/2732A-200.shtml
    They are not realy fast but they will work.
    On the shown page you can aslo download the datasheet.
    You will need a promprogrammer to put the data in the chip.
    Bertus
