Hi guys,
Some of you may have seen my ALU schematic on my 4 -Bit computer. As you can see, it uses many logic gates to instruct the alu to do diffrent functions.
Now, is it possible to have a chip of some sort that you personally program bit by bit so when a valid instruction is sent it gives an output. For example;
I send the code 1001 to the chip and it selects the artihmetic unit
Thanks!!!
Thanks!!!
