One of my hobbies is building and launch solid fuel rockets. They can be launched using fuse or an igniter of some sort. I just prefer a bare nichrome wire no larger than .0130". The wire is in a circuit and is touching the solid fuel at the rocket engine nozzle for ignition. I usually use my Ram 1500 auto battery and have ample power. But I don't want to be tied to my truck if I get a good field I cannot drive into. Batteries are bulky and unreliable unless you've got a motorcycle battery. And then you have maintenance, etc. I don't launch very often. My brother back in about 1970 helped me by putting together a circuit with a surplus army hand crank generator maybe 4" by 3" in size used by the signal corps and a capacitor (large) with a diode to indicate when the capacitor was fully charged. Actually, the igniter (nichrome) actually exploded more than glowed, but it worked. I gave all that stuff away to my nephews when I entered college. Like most hobbies I do this when I have nothing else I am involved with at any one time. I have a small generator that puts out 15 volts at a maximum of 1.5 Amps. So lets say about 12 to be comfortable, but could get to almost 15 volts if I really move. What do I need to complete the circuit including capacitor, diode, resistor(?) for me to "charge" the capacitor and maintain a 5 to 10 second red hot wire when I close my launch circuit. For me a nichrome wire at .0130" diameter 3" long between 400 and 600 degrees F. I thought this problem would be easier than it turned out. Even large capacitors just don't have the joules available to work. Voltage is very important as available energy is equal to 1/2*C*V*V. Even so my brother put together a unit from old used parts (capacitor rating unknown, but about 5" long and about 2" diameter) that worked. This is not an easy problem and I don't want to go into a trial and error method. That would be expensive. Any help would be appreciated. My background is not in science, but I have some knowledge, just not enough.
