robotics
Discussion in 'General Electronics Chat' started by redacejr, Apr 29, 2008.
  1. redacejr
    Thread Starter Active Member
    Apr 22, 2008
    85
    now that my exam is done i have free time back in my hands and i thought ill restars robotics... can anyone help with easy h birdges. im tired of all those ldr for ir an all those wires dangling off arms of my humanoids. so can anyone suggest me a compact form of an h-bridge or some ic that can be useful??
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Here's a link to Steve Bolt's 4-transistor H-bridge:
    http://www.solarbotics.net/library/circuits/driver_4varHbridge.html
    There are a number of other bridge circuits on that site.
    Here's a list of some datasheets and applications notes I've collected. You could select a few that interest you, and find the datasheets yourself on either manufacturer's websites, or places like alldatasheet.com.
    AN1681 - Applications of Monolithic Bridge Drivers (from ST Microelectronics site)
    CA3169 - SOLENOID AND MOTOR DRIVER
    CS3717AGNF16 - 1A H-Bridge Stepper Motor Driver
    CS3720XDPS7 - 2A H-Bridge Driver
    Design Tip - Bootstrap Components for Control ICs - dt98-2 (from the International Rectifier site)
    DRV592VFP - - 3-A HIGH EFFICIENCY H-BRIDGE
    DRV592VFP - +-3A HIGH EFFICIENCY H-BRIDGE
    HIP4080 - 80V, 2.5A Peak, HF Full Bridge FET Driver
    HIP4080A - an9404 - 80V HiFreq H-BridgeDriver AppNote
    HV floating MOS gate drivers - an-978 (from the International Rectifier site)
    IR2111 - Half H-bridge driver
    IR8200B - 3A, 55V DMOS H-BRIDGE
    L293, L293D - Quadruple Half-H Drivers
    L293D - PUSH-PULL FOUR CHANNEL DRIVER WITH DIODES
    L293E App1 (from the ST Microelectronics site)
    L297 - STEPPER MOTOR CONTROLLERS
    L298 Dual Full-Bridge Driver
    L298 full wave bridge driver
    L6205 - DMOS DUAL FULL BRIDGE DRIVER
    L9937 - FULL BRIDGE MOTOR DRIVER
    LM18298 Dual Full wave bridge driver
    LMD18200 - 3A, 55V H-Bridge
    LMD18201T - 3A, 55V H-Bridge
    MC34920 - 2.8 Ohm (Typ) Quad H-Bridge Motor Driver
    MPC17510R2 - 1.2 A 15 V H-Bridge Motor Driver IC
    MPC17511 - 1 Channel H-Bridge Driver IC
    MPC17529 - 0.7 A Dual H-Bridge Motor Driver with 3.0V-5.0V Compatible Logic
    MSK4201 - 28 VOLT 5 AMP MOSFET H-BRIDGE PWM MOTOR DVR-AMP
    NCV7701 - 2.0 Amp H-Bridge Driver
    STA474A - PNP NPN Darlington H-bridge
    TPIC1310KTS - 3-HALF H-BRIDGE GATE PROTECTED POWER DMOS ARRAY
    UPD168116AK9-9B4-A - 7-CHANNEL H-BRIDGE DRIVER WITH A MICRO STEP FUNCTION SUPPORTING PULSE INPUT
    UPD168117AFC-BA2-E1-A - 7-CHANNEL H-BRIDGE DRIVER WITH A MICRO STEP FUNCTION SUPPORTING PULSE INPUT
    UPD168117K9-9B4-A - 7-CHANNEL H-BRIDGE DRIVER WITH A MICRO STEP FUNCTION SUPPORTING PULSE INPUT
  3. redacejr
    Apr 22, 2008
    85
    thanks dude. really helpfull guy:):):):)
