Hello, my name is Ronnie and I need help with a project im doing for DC class,
Heres a picture of the schematic:
I need help with the varibles which are:
Q=After sw-1 is closed for 1 minute what is R1 and R1?
A= R1:____Ohms
R2:____Ohms
Q=When the capictor is switched on, what is the time constant?
A=Tc_____seconds
Q= After sw-2 has been closed for 8 seconds, what will be the voltage, ec, across the capacitor?
A=Ec______volts
Q=what is the voltage E3 across the three ohm resistor?
A= E3_______Volts
Q= What is the approximate final total Power for the entire circut?
A= PT_________watts
Q=What is the total circuit resistance?
A= Rt__________ohms
Thanks alot in advance!!
A= R1:____Ohms
R2:____Ohms
A=Tc_____seconds
A=Ec______volts
A= E3_______Volts
A= PT_________watts
A= Rt__________ohms
