RO Water Purifier
Discussion in 'Off-Topic' started by shivaaa, Mar 22, 2012.
  1. shivaaa
    Jan 5, 2011
    55
    Anybody has any idea to build our Own Reverse osmosis water purifier in Bangalore?
  2. jimkeith
    Oct 26, 2011
    539
    99
    Cannot help, but have to say that RO water has a great taste!
  3. R!f@@
    Apr 2, 2009
    8,789
    771
    Have u got the money for it ?
  4. shivaaa
    Jan 5, 2011
    55
    It comes around 10k Rupees here in Bangalore for 15Litrs. But Not sure where to get the parts to assemble.
  5. GRNDPNDR
    Member
    Mar 1, 2012
    449
    7
    eBay has all the parts or units you would need to build one.
    It's generally cheaper to buy a unit than to build it from the parts available.
    h20splash is one seller on ebay whom I've dealt with.
  6. maxpower097
    Feb 20, 2009
    795
    388
    So it can take saltwater and spit out freshwater? Wow I need one of these. On ebay their a lil over $100 for one that produces 85gal a day.
  7. R!f@@
    Apr 2, 2009
    8,789
    771
    Salt water plants a pretty expensive due to the cost of the membrane and high pressure motor. Salt water needs extreme pressure to force water molecules through the membrane
  8. maxpower097
    Feb 20, 2009
    795
    388
    Good to know, thanks.
  9. KMoffett
    Dec 19, 2007
    2,584
    234
    Do you have an adequate water supply in Bangalore to run an RO system? RO water usage efficiency is pretty bad: ..."The systems require periodic backwash to clean the filter. Depending on the model, most RO filter systems* will discharge 4 to 20 gallons (15.1 L to 75.7 L) of backwash water for every gallon of filtered water it produces."...http://www.allianceforwaterefficiency.org/RO_Discharge_Introduction.aspx
    Ken
  10. GRNDPNDR
    Member
    Mar 1, 2012
    449
    7
    I don't know if you know but they produce a lot of waste water too. for the 85Gal per day you could be wasting hundreds of gallons that just go down the drain.
    Also they will only produce their rated amount with a higher pressure, usually 100PSI.
    Shurflo makes some decent pumps for this purpose.
    My RO unit is a 7 stage, and produces water too clean to even drink, but also has a pump. It cost me just about $250 for the entire setup and $100 of which was the pump.
    There are also a few other parts thaty can be purchased to enhance the functionality of an RO unit, but permeate pumps are NOT one of those things.
  11. maxpower097
    Feb 20, 2009
    795
    388
    Water doesn't have to be drinkable, just desal.'ed. Since its saltwater I have an endless supply of water. I really only need about 2-5 gallons a day. So I won't need that much. My main concern is gonna be power. Which will need to be run off of solar panels and batteries.
  12. KMoffett
    Dec 19, 2007
    2,584
    234
    I was referring to the OP's situation.
    Ken
  13. maxpower097
    Feb 20, 2009
    795
    388
    I know, I wasn't referring to you. I was just describing my application of it.
