I did some development work on my breadboard using an RN-41 BT breakout from sparkfun. It worked really well, and at great distances on my breadboard.
Later, I developed and fabricated a PCB for the same circuit, and integrated an RN-41 module into it. Unfortunately, the range that I can transmit from my PCB is very short/weak - about 10 feet or so instead of 100+..
I verified that the RN-41 is set to transmit in it's highest power mode, but I don't think that is the problem. I feel that there is a hardware issue of some kind.
I do have a little bit of metal beneath the antenna on my PCB, in the form of my name, and a single trace passing by. It would surprise me if this was the problem, since my range limitation is so profound.
There are pads on the underside of the module that are supposed to be grounded per the data sheet, but research I did on this indicated that people generally don't connect those. Thus, I didn't connect them.
I've attached an image of both sides of my board, plus a schematic of the RN-41 connections. I sketched in the placement of the RN-41 in red, and depicted its antenna in blue. The RN-41 pads not shown as connected in the schematic are sitting on pads, but not soldered to them.
If anyone has any thoughts or experience on this matter, I'd really appreciate any suggestions.
Kind regards,
Eric
PS - perhaps I should have put this thread in the RF forum..?
Kind regards,
Eric
