RLC, when in series ? when in parallel ?
Discussion in 'Homework Help' started by Hitman6267, May 29, 2010.
  1. Hitman6267
    Apr 6, 2010
    82
    In the solution of this problem they wrote alpha= R/2L. That formula applies when its a series RLC. What elements of the circuit are we talking about when we're saying series/parallel. I used to think it was the inductance and the capacitor. Does opening the switch making the inductance capacitor resistor a separate circuit has anything to do with it ?
    Here's how I think if i'm asked to find i(t) -current through the inductance - for t > or = 0
    I get i(0) so I get a relationship like this A1+A2 =0
    then I derive the general equation of the case.
    => di/dt = ...
    then I think that di/dt isn't "anything" so I remember that the voltage of a inductance is V= L di/dt. so I multiply both sides of the newly derived equation to get V= ...
    In this circuit V(0) would be 0 because the inductance became a wire.
    Is this a wrong way to think ? It's never working for me.
    Back to the solution I posted. How did they find di(0)/dt ?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Yes - this is a series circuit. There is only one path through which current may flow around the remaining RH loop when the switch opens - hence no parallel paths exist.
    If you consider the initial circuit conditions - starting with the general DE for vo(t) in terms of the LH side of the loop
    v_{o}(t)=Ri_{o}(t)+L\frac{di_{o}(t)}{dt}
    Hence
    \frac{di_{o}(t)}{dt}=\frac{1}{L}(v_{o}(t)-Ri_{o}(t))
    At t=0
    v_{o}(0)=75V
    i_{o}(0)=15mA
    \frac{di_{o}(0)}{dt}=\frac{1}{L}(v_{o}(0)-Ri_{o}(0))
    \frac{di_{o}(0)}{dt}=\frac{1}{1}(75-5000*15e^{-3})=0
  3. Hitman6267
    Apr 6, 2010
    82
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    15e^{-3}
    is meant to be scientific format notation - for the 15mA value. I'm surprised you didn't realise that.
    perhaps I should have either written more correctly [by convention]
    15E^{-3}
    or
    15*10^{-3}
    I tend to use notations interchangeably & somewhat ambiguously perhaps.
    In any case the solution I gave is correct if you allow my intended meaning.
    Hitman6267 likes this.
  5. Hitman6267
    Apr 6, 2010
    82
    ok That makes sense. Thank you.
