RLC Timer
Discussion in 'General Electronics Chat' started by Ambassador, Jun 13, 2014.
  1. Ambassador
    Jun 13, 2014
    10
    Can any here post a reference to a one [1] minute timer circuit schematic that uses only passive RLC components?
    If not a one [1] minute timer, then any close span of time would be useful.
  2. inwo
    Nov 7, 2013
    2,435
    315
    Can you use a solid state relay?
    What is the load?
  3. wayneh
    Sep 9, 2010
    12,379
    3,232
    Maybe such a thing is already out there, but without looking, the request made me think of my "ring tester", which is designed to ring a coil to test it for inductance. The tester sends a pulse and then watches for (and counts) the peaks of the damped LC oscillation. It would be a small thing (easy for me to say) to adapt that to a clock application.
    That said, in my case the pulses were generated by a 555, so there would be no need to add the complexity of LC ringing in order to build a clock. I suppose you could trigger pulses with some other arrangement.
    It's worth noting that the LC will not oscillate for more than about a second before it needs a fresh ping. There's always an R in the RLC. I suppose a big L and a big C could give you a minute of ringing.
  4. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,687
    1,297
    Your question needs a lot of work.
    What is the application?
    What power is available for the timer?
    Is there a load to be switched by the timer, or just some kind of indication?
    What starts the timer?
    ak
  5. Ambassador
    Jun 13, 2014
    10
    Thank you - you folks are quick!
    inwo,
    Regarding "Can you use a solid state relay?" - no.
    Regarding "What is the load?" - the circuit's output terminals need only provide some sort of indication.
    AnalogKid,
    Regarding "What power is available for the timer?" - a 12V dc battery source.
    Regarding "Is there a load to be switched by the timer, or just some kind of indication?" - just an indication.
    Regarding "What starts the timer?" - a physical switch.
  6. crutschow
    Mar 14, 2008
    13,482
    3,370
    Why do you need an inductor (?), just use an RC timer.
  7. Ambassador
    Jun 13, 2014
    10
    crutschow,
    Regarding "Why do you need an inductor (?), just use an RC timer." - that would be okay.
  8. crutschow
    Mar 14, 2008
    13,482
    3,370
    So an R of 100k ohm in series with a 270 microfarad capacitor to ground will charge up to 89% of the applied voltage or 10.7V in 60 seconds after the 12V is applied to the circuit.
    But you need something to determine when that voltage is reached. Don't see how you can do that with only passive components. :confused:
  9. LETITROLL
    Member
    Oct 9, 2013
    218
    I guess using transistors is necessary for an astable timer , they will act as chargers and dischargers .
    Impossible to make an active application using only passive components .
  10. inwo
    Nov 7, 2013
    2,435
    315
    What type of indicator is allowed?
    A meter, led, neon? Relays are out! How about fuse, zener, scr, mov?
    There are chemical indicators. LCDs and the little test strips on batteries.
    Give us something to work with.:D
  11. inwo
    Nov 7, 2013
    2,435
    315
    With led and zener.
    Discharge not shown.
    If zener not allowed triple R1.
    If led not allowed, guess you'll have to use a cat.:D
    It works surprisingly well!
    Couple seconds turn on ramp.
    absf likes this.
  12. Ambassador
    Jun 13, 2014
    10
    Regarding "What type of indicator is allowed ... Give us something to work with" - okay, any small dc motor.
  13. inwo
    Nov 7, 2013
    2,435
    315
    Ok, so a motor is allowed but not a relay or transistor to control it...:confused:
    Next question. Why the limitations?
    As you may guess. I'm stumped.:D
  14. wayneh
    Sep 9, 2010
    12,379
    3,232
    +1
    What are we doing? You started off wanting an LC timer, so I assumed there was some un-stated requirement to use an inductor. What other un-stated rules do we not know about?
  15. Ambassador
    Jun 13, 2014
    10
    Regarding "... started off wanting an LC timer ..." - the post references a timer that uses only passive components like RLC components.
    The small dc motor was suggested because inwo made the good point "What type of indicator is allowed ... Give us something to work with."
  16. LETITROLL
    Member
    Oct 9, 2013
    218
    Is that some extinct style of posting in forums :D
  17. Ambassador
    Jun 13, 2014
    10
    Incidentally, the RLC timer circuit is to be fashioned as would have been possible before semiconductor materials were available.
  18. inwo
    Nov 7, 2013
    2,435
    315
    Relays were available since forever.:D Why no relays?
  19. Ambassador
    Jun 13, 2014
    10
    Relays that are not based upon semiconductor materials are okay.
    (Sorry about that)
  20. Bernard
    Aug 7, 2008
    4,237
    414
    Finally we know what we are looking for.
    Values may be off a little. Made R 1/10 of coil resistance.
