hi all,
I have an RLC parallel circuit with a capacitor in parallel with a resistor / inductor in series ( representing a coil ). There is a 1v peak AC supply and I need to calculate the voltages, currents, angles etc and draw the resultant phasor.
When calculating the current in the resistor / inductor branch do I use the 1v peak supply stated or convert to rms (*0.707) first of all.
Irl = 1 / z or Irl = 0.707 / z
The same applies to the capacitor current
Ic = 1 / Xc or Ic = 0.707 / Xc
As stated I need these values to be correct to draw the resultant phasor diagram
Thanks in advance
Thanks in advance
