RLC Circuit State-Space & Transfer Function Help
Discussion in 'Homework Help' started by Elecmanic, Feb 29, 2012.
  1. Elecmanic
    May 12, 2010
    6
    1. Question Paper
    Can you please help me out to solve this question. I cannot do it for sure, the problem is if possible i need it very fast :/
    Thanks & Regards
    Elecmanic
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    I edited your post to make the image readable.
    Have you done anything already? Are you supposed to use the Laplace Transform variable 's' for the Transfer Function?
    If that's the case, keep in mind that Z_C=\frac1{sC} and Z_L=sL, where Z is the impedance, C is the capacitance and L is the inductance.
  3. panic mode
    Oct 10, 2011
    1,330
    305
    Z1= 1/sC1 + sL1
    Z2= (1/sC2)|| (sL2) = (sL2/sC2)/(1/sC2+sL2)
    Z2= sL2 / (1+s^2L2C2)
    using voltage divider rule
    Vo = Vi * Z2/(Z1+Z2)
    then transfer function is
    T(s)=Vo(S)/Vi(s) = Z2/(Z1+Z2)
    etc.
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    It is nice that you want to help a fellow student, but it's best if you don't give him the answer outright. Let him make an initial effort, in order to "earn" the answer.
    timekeeper likes this.
  5. panic mode
    Oct 10, 2011
    1,330
    305
    Sorry, I will try to follow this idea from now on...
