RLC circuit for defibrillation test
Discussion in 'The Projects Forum' started by moneyk, Feb 26, 2008.
  1. moneyk
    Feb 26, 2008
    9
    I want to make a RLC circuit in order to simulate a defibrillator.
    A have attached a word document showing the circuit and the desired output. I would greatly appreciate if I could get any help regarding the desigin of the switch.
    Thanks a lot,
    Manish.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    A single pole double throw relay under control of a 555 timer would let you do the switching at a reasonable simulated heart rate.
  3. moneyk
    Feb 26, 2008
    9
    I have looked for a lot of SPDT relays. The relay should have low on resistance and also should be able to handle atleast 150 Voltage Output. Any suggestions on the relay?
