hello
I have simulated a rlc series circuit with values, 4.7k ohm, 151 mH, 1uF.
I have set this up on multisim and used AC analysis to show what I think is the bandwidth.
hopefully you should be able to see this clearly. I have 10vpk, making 20vpk-pk. I used 20 * 0.707 to get the -3db, half power point, giving 14.14 volts. I set the cursors at this value either end to show what I believe is the bandwidth.
is this correct?
is this correct?
