This is getting funny now. You guys seem to refuse to read all the posts so you miss information presented.
Electrician:
I agree with Mike on the resonance and power factor correction. Note that the inductor draws the same current with or without the cap being present for all frequencies.
Mike:
I agree with Electrician in that there is still some behavior we might call resonance. Note that if you use the formula for resonance, you can come up with the cap value!
Both:
You guys will argue these points forever because you both cant accept that there are at least two types of what we call resonance. One of you 'believes' that the opposite definition is the only true one. This isnt religion here, it's science.
Here is the current amplitude function:
I(w)=100*sqrt((9*w^2)/625000000+25.0/w^2-83/90000)
There is an amplitude min at f=32.5 approximately (and w=2*pi*f) equal to 1.66667 amps.
I might add that it is not a very sharp response, but it is still a dip meaning that the current is greater than the min of 1.66667 amps for frequencies lower and higher than the center frequency.
Electrician:
Mike:
Both:
