RLC at resonance
Discussion in 'Homework Help' started by JoyAm, Sep 4, 2014.
  1. JoyAm
    Aug 21, 2014
    112
    Hello, I tried to solve a simple "problem" with an series rlc circuit at resonance, what i wanted to find was
    1) if voltage magnification will occur
    2)VL , VC , VR , I0
    3)The circuits power at resonance
    I attach two print screens of the circuit( given Vs, L,C,R) and my solution attempt.
    Is the way i try to solve it right ?
    http://prntscr.com/4jmlsg
    http://prntscr.com/4jmm8j
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    The circuit has such a low Q that the Voltage Magnification at V(a) is barely perceptible.
    Here is the complete solution. You can check to see if your work matches this:
    JoyAm likes this.
  3. JoeJester
    Apr 26, 2005
    3,402
    1,227
    Here are two "cheat" sheets that talk about the characteristics of resonant circuits.
    JoyAm likes this.
  4. JoyAm
    Aug 21, 2014
    112
    Thank you for your immediate answers Mike and Joe.
    What i really need to know is
    1) how will i know if a voltage magnification will occur ( what i can think of is to check the voltage on either capacitor or inductor (assuming I=Vs/R) and then check if its bigger than the one in the resistor, which will be the same with the source Vs , is that right ?)
    2) the power of the whole circuit will be Vs^2*R because the sum of the capacitor and inductor is zero ?
    Thanks in advance :)
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    I have never heard the term "voltage magnification" until your post. The concept is tied up to the Q of a resonant circuit, so read up on Q.
    I already showed you the power into the circuit (the expression V(1)*-I(V1) shown in the bottom plot pane). Since L and C are ideal, lossless components, then it follows that at resonance, the power in the resistor is the same as the input power.
    JoyAm likes this.
  6. JoyAm
    Aug 21, 2014
    112
    1)Maybe i am using the wrong term then. What i mean is that at resonance we have VL=-Vc and Vs=VR
    That makes the VL and VC able to much higher than Vs and when that happens we call it voltage magnification ( if there is another term that describes this phenomenon please let me know).
    2)So the power of the circuit at resonance is equal with the power in the resistor, right ?
  7. JoeJester
    Apr 26, 2005
    3,402
    1,227
    At best, Vc and Vl will be the Q x E line. Look at that cheat sheet for series resonant circuits at fr.
    JoyAm likes this.
  8. JoyAm
    Aug 21, 2014
    112
    So we come to the conclusion that in this circuit(with these values of Vs,R,L,C) even when it is at resonance, no voltage magnification occurs, am i right ?
    Also about your cheat sheet, i think that you use the value of Vs=10volt in your calculations, but when we are given the peak to peak voltage, dont we have to divide it by 2 to get the V0?
  9. JoeJester
    Apr 26, 2005
    3,402
    1,227
    When I used 10 volts pk to pk all other values were peak to peak.
    If I were going to use rms, I would have done more than divide by 2.
    If you were going to take the readings using an oscilloscope, they would be pk to pk.
    JoyAm likes this.
  10. MikeML
    Oct 2, 2009
    5,451
    1,066
    Here is a plot of the "magnification" that occurs in V(a) as a function of frequency with R1=1000. Note it increases only ~ 1%:
    Here is a plot with R1=10, a much higher Q:
    JoyAm likes this.
  11. JoyAm
    Aug 21, 2014
    112
    Well that what solved all my misunderstandings ( i was blind to it all the time although your were trying to make me see it )
    So to sum up, if Q>1 that means we will have a voltage magnification :)
    Thanks both of you once more
