Please help me analyse this circuits. Here's my reasoning; for the positive half cycle, D2 is on and D1 if off. As current flows, the Inductor is energized, as Vs goes to 0( negative half cycle, then D2 is off, D1 is on. At the point D1 is on, the inductor sends current through D1 untill it's fully depleted. During that depletion stage, i assumed that the voltage would start out being as high as Vs but it seems not. Could you please explain what's happening and what causes the oscillation between the rectified cycles?
