RL circuit transient response
Discussion in 'Homework Help' started by stupid, Nov 9, 2009.
  1. stupid
    Thread Starter Active Member
    Oct 18, 2009
    81
    i m at a loss to how the answer is arrived.
    iL= -(R/L)∫(iL-(E/R))dt, where limit is i(t) & Io
    the answer provided is,
    i(t)=e^(t/τ)(I_{o}-(E/R)) + E/R
    i m stuck, pls help
    thanks & regards,
    stupid
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Differentiate the equation in iL with respect to time (both sides) and solve the resulting differential equation.
  3. stupid
    Oct 18, 2009
    81
    hi tnk,
    there is no t element with either iL & E/R
    how can i proceed?
    i thought it should be integration instead of differntiation?
    regards,
    stupid
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    That current and voltage depend on t is implicit. If they did not there would be no need for differential equations since nothing would ever change. In cases like this you can expnad the short hand as follows:
    i -> i(t) ; i(t) is a function of t, but we do not yet know the form of this function
    The derivative of i(t) is just d/dt[ i(t) ], and since we don't know the form of i(t) we cannot know the form of di/dt. However, the differential equation puts a severe restriction of the form of i(t) and therefore di/dt. Once you see the form of a differential equation you can make an ansatz
    http://en.wikipedia.org/wiki/Ansatz
    and the solution falls right out.
    Does that help you out a bit?
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    Hi s,
    Can't bring myself to call you stupid - seems not polite.
    My attachment is pdf of a solution
    rgds,
    t_n_k
  6. stupid
    Oct 18, 2009
    81
    thank u tnk.
    i need to digest & reflect upon my weakness.
    do expect i may come back with questions related to that.:D
    regards,
    stupid
  7. stupid
    Oct 18, 2009
    81
    i m trying another way, say
    given iL= -(R/L)∫(iL-(E/R))dt
    diL/(iL-(E/R))= -(R/L)dt
    iL/(iL-(E/R))= ∫-(R/L)dt -----eq1
    (i have a feeling the above eq may b wrong.)
    however we know say y=2x^{2}
    dy/dx = 4x
    dy= 4x. dx
    y= ∫4x.dx
    given that logic i cant reprove eq1, can i?
    regards,
    stupid
  8. t_n_k
    Mar 6, 2009
    5,448
    783
    No - You can't do that.
    Essentially, you've re-arranged things in the same manner as I did before making the change of variable substitution [z(t)=iL(t)-(E/R)] - which I did to allow me to more easily perform the integration of both sides.
    Remember ∫(1/x)dx=ln(x)
