RL circuit analysis help
Discussion in 'Homework Help' started by Cooper1228, May 16, 2015.
  1. Cooper1228
    May 16, 2015
    I need help calculating the predicted values of this circuit. Also I don't have access to an oscilloscope at the moment so just knowing if the values end up close to the predicted would be helpful as well. WP_20150516_007[1].jpg
  2. Cooper1228
    May 16, 2015
    Woops didn't mean to make that so big. This is my first post.
  3. panic mode
    Oct 10, 2011
    1,328
    305
    you do know that
    |Xl|=ωL
    and what ω is?
  4. WBahn
    Mar 31, 2012
    18,085
    4,917
    So... you need to show YOUR best efforts to work YOUR homework problems. Make you best attempt to come up with the predicted values, showing your work, so that we can see where you are going right and where you are going wrong.
