RL and LRC circuit clarification
Discussion in 'Homework Help' started by graves53, May 1, 2013.
  1. graves53
    May 1, 2013
    I'm doing a lab and I am kind of confused about some of the concepts. For the RL circuit is the inductor and resistor voltages the voltage output for both or do i have to calculate the output? Also it says there is a frequency that both the output and input voltages for both the resistor and inductor should be equal, how would I calculate that?
  2. WBahn
    Mar 31, 2012
    18,089
    4,917
    Is this a series RL, a parallel RL, what?
    It would REALLY, REALLY help if you included some kind of a schematic. My crystal ball needs new batteries and I've never been a good mind reader.
    Also, label the voltages you are referring to in your text. I have no idea what you mean by "is the inductor and resistor voltages the voltage output for both." What are you referring to by "the voltage output for both"?
  3. graves53
    May 1, 2013
  4. WBahn
    Mar 31, 2012
    18,089
    4,917
    Okay, I now have a pretty good idea of what you are supposed to be doing, but I still can't make heads or tails out of your questions. Please rephrase more carefully and explicitly.
