RJ45 modbus cable to D9 connector
Discussion in 'General Electronics Chat' started by Boardwalk, Jun 5, 2016.
  1. Boardwalk
    Jun 5, 2016
    Hi people,
    I have a stripped RJ45 cable to whom i need know how to make the wire connection in a D9 connector, in order to match the pinout of a MPI-Bus adapter.
    How should i connect the wires from the RJ45 cable to the D9 connector?
    Thank you in advance,
    Boardwalk
  2. AlbertHall
    Jun 4, 2014
    2,261
    447
    That depends what you are going to connect the other end of the RJ45 cable to. The XBT ZG9292 cannot be connected to Ethernet however you wire it.
  3. Boardwalk
    Jun 5, 2016
    I'm going to connect the other end to a COM1 port with the following pinout:
  4. AlbertHall
    Jun 4, 2014
    2,261
    447
    So maybe:
    RXD - RX
    TXD - TX
    RTS - RTS
    SG - GND
    But I suggest you call the manufacturer. Damage is possible as some 'RS232' ports use 0V to +5V and some use -15V to +15V.
  5. mcgyvr
    Oct 15, 2009
    4,787
    973
    Does the RJ45 plug into the MPI bus adapter and you want the db9 to plug into the com port right?
  6. Boardwalk
    Jun 5, 2016
    No, the RJ45 plugs into the COM1 port of a HMI touchpanel and the db9 plugs into the MPI-Bus adapter.
