Risk of damage using an unregulated power supply
alvescarlos
Joined Jul 4, 2015
Hello to all,
I have an unregulated Power Supply with output specs of 1.5-3-4.5-6-7.5-9-12V an 1000mA 12VA (max). As with all unregulated power supplies, when I measure its output at 9V setting, I get about 14V. I understand that with this power supply when the device consums about the 1000mA, then I would get the 9V output.
What I would like to know if it's Ok to use this power supply to power a device that needs to be powered at 9V, with a consumption of no more than 80mA, or am I having the risk of damagind the device? Should I use the power supply at a lower output voltage so I can get something more around the needed 9V?
Thank you very much in advance.
Cheers!
dl324
Joined Mar 30, 2015
16,846
Under full load, you should get 1.414*9=12.7V.
It depends on whether the device will tolerate voltages higher than 9V, or lower.
DickCappels
Joined Aug 21, 2008
10,152
If your power supply peaks are within are under 10 volts there is little chance of damage.
A good solution would be to follow the 12 volt output with a 9 volt regulator such as an LM7809.
34,285
You might also consider using one of the lower voltage outputs whose open circuit voltage is closer to 9V when loaded with 80mA.
If you know the load is 80mA, then a dropping resistor of R= V/.080 where V is the desired voltage drop (5V?).
Using 5Vdrop I calc about 62Ω required. Power = .08x.08x62 = 400mW. You can squeak by with a 1/2watt rated resistor with decent air flow. 1 watt is better.
ian field
Joined Oct 27, 2012
6,536
Hello to all,
Cheers!
The regulation on those old iron-cored transformer PSUs is pretty dire, you can sometimes find better ones with an LM317 behind the voltage selector switch.
If you don't mind investing a bit of cash in not blowing stuff up - tight regulated SMPSU versions of the switchable voltage PSUs are becoming more common.
Hypatia's Protege
Joined Mar 1, 2015
3,228
Amen!:D
