1. diwa2000@gmail.com
    Thread Starter Active Member
    Apr 15, 2008
    40
    Hello
    Could somebody suggest how could the output of the peak detector that has ripples be removed. I mean I want to remove the ripples ...does the ripples appear at 433MHz from the output of peak detector.
    please suggest.
    thanks
  2. diwa2000@gmail.com
    Apr 15, 2008
    40
    please help to the above question. if any more data is needed please post back.
    thanks
  3. mik3
    Feb 4, 2008
    4,846
    63
    Calculate R*C to be 10 times greater than 1/f
    where R=the resistor in parallel with the capacitor C
    C=the capacitor
    f=your frequency
    Are you sure you have 433 MHz frequency?
    What is your circuit built of?
  4. cumesoftware
    Apr 27, 2007
    1,330
    11
    You can't remove the ripple entirely, but you can also use this formula:
    C = Iload / (Vripple * f) for an approximation.
    mik3's formula is correct considering 10% ripple (Vripple / Vtot = 0.1).
