Ripple voltage in Rectifier circuit
Discussion in 'Homework Help' started by cicada207, Nov 1, 2015.
  1. cicada207
    Nov 27, 2014
    Hi....
    I have a problem when calculate Ripple voltage in half/full wave rectifier
    Following formula of Ripple voltage
    Vr\doteq\frac{Vom}{fRC}
    (HWR)
    e.g [tex]V_s= 9V [/tex]
    R= 1k (ohm)
    C = 22uF
    => [tex]V_om=V_sm-V_\gamma =12.7 -0.7 = 12V
    =>V_r = 10.9V
    =>V_omin = V_om-V_r=12-10.9=1.1(V)[/tex]
    BUT when I simulate circuit in Proteus
    Result [tex]Vomin= 5.8(V)[/tex][plain]
    please help me explains this thing!
    Thanks.
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    Well, the answer is quite simple. Your equation gives you only an approximate value for Vr (worst case ever). Because your equation simply assumes that capacitor is discharging via constant current and do not take into a count the diode conduction angle. Also there is no single equation that will give as the exact ripple value.
