Ripple of a Amplifier over frequency range
Discussion in 'Wireless & RF Design' started by Terry Chapman, Dec 20, 2010.
  1. Terry Chapman
    Mar 15, 2007
    The gain measurements on an amplifier indicate the following readings over the frequency band of interest: 10.3 dB, 10.8 dB, 10.6 dB, and 10.4 db.
    How can I calculate the amplitude ripple ?
    TERRY
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    The (voltage or power ??) gain variation is 0.5dB over the region of interest. This can be translated to an output voltage variation for a known input signal level.
    So is the stated gain a power gain or voltage gain?
  3. Terry Chapman
    Mar 15, 2007
    Thanks t_n_k,
    But how did you get 0.5 dB. The gains in dB over the frequency range is voltage. Please describe how you determined the variation over the frequency range is 0.5 dB, I assume this involves S-Parameters of the ripple in the frequency range.
    Thanks again,
    Terry
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    Well the minimum gain was quoted as 10.3dB and the maximum was given as 10.8dB. The maximum stated difference or variation then is
    10.8dB-10.3dB = 0.5dB.
    Terry Chapman likes this.
