Ripple looks like noise?
Discussion in 'General Electronics Chat' started by davidowens, Oct 3, 2014.
Thread Status:
Not open for further replies.
  1. davidowens
    Oct 3, 2014
    12
    When I'm measuring ripple it looks like noise
    Can ripple look like noise or is ripple noise?
    Mostly I'm use to seeing ripple as a sawtooth discharging waveform it doesn't look like noise but other AC power supply ripple looks like noise
    How does a tech know if this is AC ripple or noise?
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    Depends on one's definition of noise. 50Hz, 60Hz and 400Hz ripple can also constitute noise.
    If you are looking for ripple, then sync your scope to line frequency. Otherwise noise is usually random.
    By the way, Dan, Dave, David or Vinny, your little game is exposed.
    djsfantasi likes this.
  3. davidowens
    Oct 3, 2014
    12
    60hz ripple looks like a trianglish discharging waveform
    400hz ripple look likes random noise to me
    There is different trigger modes on the O-scope:
    With the external trigger or set the trigger to channel#1 or trigger to line?
  4. vk6zgo
    Jul 21, 2012
    677
    85
    If you are using a fullwave rectifier,your "ripple" should be 120Hz ,with the waveform you describe.
    A halfwave rectifier will give you 60Hz "ripple".
    You may also see 60Hz which looks like a sinewave this is what you would normally call "mains hum"---this is not "ripple" from your power supply..
    Where do you get the 400Hz from?
    I was thinking of 3 phase supplies at 60Hz,but that would be 180Hz in the halfwave case,& 360 Hz in the fullwave case.
    The other possibility is military 400Hz power supplies.
    Single phase,these would give you 400Hz "ripple for a halfwave rectifier & 800 Hz for a fullwave rectifier.
    If you set your 'scope to trigger from "line",it will trigger at the 60Hz mains rate.
    If the signal you are observing is stable,it is derived from the mains frequency,
  5. davidowens
    Oct 3, 2014
    12
    Yes the power supplies are 400hz and others are 800hz
    A 400hz ripple looks like noise to me and also the 800hz ripple looks like noise to me
    How would you set up the O-scope to measure 400hz or 800hz ripple?
    Ok maybe i'm confusing the two
    How do you know what is ripple or hum?
    Because I set my Oscope to AC Coupling on channel#1 and put the Oscope triggering to trigger to Channel#1 input. The waveform looks like a sine waveform in millivolts, is this ripple or hum?
  6. NorthGuy
    Jun 28, 2014
    611
    121
    Depending on the ratio of the sampling drequency of your scope to the frequency of the ripple, a relatively regular vaweform may look like a noise.
  7. davidowens
    Oct 3, 2014
    12
    I have tried the Average Mode and Bandwidth mode to take away the noise out of the ripple, it doesn't help much when measuring 400hz or 800hz ripple
  8. BR-549
    Sep 22, 2013
    2,168
    416
    Do you have a schematic? Where are you measuring the ripple-noise-hum at in the circuit?
  9. davidowens
    Oct 3, 2014
    12
    On the output of the regulators
    Measure the Positive supply ripple on the positive regulators output after the filter caps
    Measure the Negative supply ripple on the negative regulators output after the filter caps
    What is VR2 diode for? not sure why the negative supply only has a VR2 diode because the positive regulator doesn't have one, any reasons why?
    Q19 and Q20 are series pass transistors
    Not sure why the Negative regulator has two series pass transistors compared to the positive regulator only has one series pass transistor Q21 , any reasons why?
    Why does the Negative Regulators input uses the Positive regulators output?
    Most dual power supplies I have seen both positive and negative regulators go Direct to the diode rectifier
    but this power supply uses the positive regulators output as the negative regulators input, any reasons why?
  10. BR-549
    Sep 22, 2013
    2,168
    416
    Would you please retake that pic. I need to see everything on that sheet of paper. I am dyslexic. Thank you.
Thread Status:
