Have you even tried?Hello
I need help to understand logic of ripple counter. I understand the operation of d flip flops.
I understand the operation of first flip flop but I don't understand what will output of second and third flip flop
I am stuck here. If there is no input data then how to know behavior of counter. I have seen in book. D input should be connected to /Q.Hello,
What do you use for the input signal at the D inputs of the flip-flops?
When D does not change, the output will not change.
Bertus
You don't have an input to any of the flip flops, so how can you say what the input is?I think the response of counter should be below
At first raising clock
Input I2,I1,I0=000
Output q2,q1,q0=000
At second raising clock
Input=010
Output=010
At third raising clock
Input=011
Output =011
....... So on
Counter count number 01234567
Am I correct?
by Aaron Carman
by Duane Benson
by Duane Benson
by Jake Hertz
