Ring oscillator
Discussion in 'General Electronics Chat' started by Ahmad Aldabbagh, Jun 5, 2015.
  1. Ahmad Aldabbagh
    Jun 5, 2015
    7
    Hi all
    Could you help me please to design a ring oscillator circuit using MOSFET inverters ( 5 stages ) to get a frequency about 20 MHz ?
    - recommended software is LTspice or Multisim
    Thanks in advance for your help
  2. Alec_t
    Sep 17, 2013
    5,979
    1,138
    Welcome to AAC!
    Is this a school/college project?
  3. Ahmad Aldabbagh
    Jun 5, 2015
    7
    no
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  5. crutschow
    Mar 14, 2008
    13,509
    3,385
    If this is not homework, who recommended LTspice or Multisim?
  6. Ahmad Aldabbagh
    Jun 5, 2015
    7
    I need to work on these two programs
  7. atferrari
    Jan 6, 2004
    2,670
    785
    Google for application notes from National Semiconductors. I recall at least two of them explaining the basics.
  8. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,705
    1,300
    The problem with the ring oscillator is that it is critically dependent on device factors that are not critically controlled during manufacture. Beyond the obvious suggestion of an integrated or discrete crystal oscillator, there are other non-resonant oscillator structures that give you more control over its design and operation. 20 MHz might be a bit high for a classic phase-shift oscillator, but you could do one with ECL gates.
    ak
  9. Ahmad Aldabbagh
    Jun 5, 2015
    7
    Yes that is right. Actually I have to use MOSFET in order to save power and in the meanwhile I got 25 Mhz using 3 stages inverters and supply voltage of 8v. This voltage is considered high and I need to reduce it but the problem is that there no output waveform when the voltage reduced below 8v. do you have suggestion about what type of MOSFET I have to use with low voltage needed?
  10. AnalogKid
    Aug 1, 2013
    4,705
    1,300
    Can you post your schematic?
    ak
  11. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    For a 5 gate ring oscillator wich should produce 20 Mhz, you would need a propagation delay of total 50 nS.
    This will yield to a propagation delay of 10 nS for one gate.
    This can be found in TTL chips, but cmos will be most likely to slow.
    Bertus
  12. Ahmad Aldabbagh
    Jun 5, 2015
    7
    Please find the attached schematic
  13. dl324
    Mar 30, 2015
    3,384
    653
    Are you trying to design with 5 stages, or 3? What is your desired operating voltage? Any reason why you're using high current devices?
  14. Ahmad Aldabbagh
    Jun 5, 2015
    7
    dear Dennis,
    '' Are you trying to design with 5 stages, or 3?'' ....... I need to design both of them.
    ''What is your desired operating voltage?'' ................ the desired voltage is 3.3 v .
    ''Any reason why you're using high current devices?'' ............. no, please advise me if you have suggestion about type and serial number of the MOSFET transistor.
    thanks
  15. dl324
    Mar 30, 2015
    3,384
    653
    Look for some low threshold voltage devices. I think it's going to be difficult to get 5 stages to work at 3.3V; even 3 stages may be difficult. Don't use power devices; larger devices mean more parasitics and you don't need the drive capability.
  16. AnalogKid
    Aug 1, 2013
    4,705
    1,300
    With all of its amplitude and frequency stability issues, why are you focused on a ring architecture?
    ak
  17. Ahmad Aldabbagh
    Jun 5, 2015
    7
    I need it in a specific application
