Ring oscillator frequency vs supply voltage variation
Discussion in 'General Electronics Chat' started by anhnha, Jan 14, 2016.
  1. anhnha
    Thread Starter Active Member
    Apr 19, 2012
    776
    48
    As you may know, the oscillating frequency of ring oscillator changes significantly with supply voltage variation.
    Are there methods to reduce this effect?
  2. dannyf
    Sep 13, 2015
    2,196
    417
    Fixed the supply voltage?
    This effect allows them to be used as vco.
  3. DickCappels
    Aug 21, 2008
    2,783
    676
    Probably, the key would be to make a stage with a delay that has only a small dependency on power supply voltage, and that would be highly dependent on the topology of the inverters in your oscillator.
    If you were to change the inverter to latches clocked by a stable (example: quartz) clock source, taking the outputs from NOT-Q there would be little dependency on the power supply voltage.
  4. ErnieM
    Apr 24, 2011
    7,443
    1,628
    By any chance would you have a schematic of the circuit you have in mind so some specific comments can be made?
  5. anhnha
    Apr 19, 2012
    776
    48
    Thanks for the help.
    No, supply voltage varies a lot. So I need to fix frequency.
    I am using the inverter topology as below. Are these some ways to reduce the dependency?
    I can't use quartz here so it would be difficult.
