Hi folks,
I like to apply the idea that the manufacturers use on the rigid LED-strip but on a different thing.
I like to make a 13-15w high lumen lamp that can be connected together like christmas light strings. The end user could use one 15W PCB (bunker light) or simply connect one more to the first one, or connect a third to the second.
If i like to make this PCB around 100 mm in diameter, it should have 15w, led connectors for connecting from the driver and to connect to another lamp if user like, how can i do this?
I am not even a beginner so if you know the answer please be patient.
I like to make this, just to show my dad that it can work like this. The Voltage can be any voltage, i have plenty of different drivers.
So, to my 150W driver, i like to be able to connect one 15w LED PCB and many without changing the driver, they should be connected like in a string.
