Ridiculously stupid question. DPST switch
Discussion in 'The Projects Forum' started by CRNUT, Feb 7, 2008.
  1. CRNUT
    Feb 7, 2008
    8
    This would have been easy for me back in the day but I am lost right now. I want to control 2 12V light bulbs with a SPDT switch. The switch needs to light one bulb in one position and both bulbs in the other position. Every diagram I can think of will light both bulbs in both positions. Can't be that hard maybe just a diode somewhere. Can anyone draw me up a simple diagram?
  2. nomurphy
    Aug 8, 2005
    567
    12
    No, with just a switch you will need a DPDT. Otherwise, it will require a logic circuit.
  3. CRNUT
    Feb 7, 2008
    8
    So no easy way around this even if I control the bulbs with relays?
  4. kubeek
    Sep 20, 2005
    4,691
    806
    Well if one of the bulbs is always on, you could just switch the other on and off.
  5. nomurphy
    Aug 8, 2005
    567
    12
    Yes, you could use a relay or two to make a logic circuit. But why not just use a different switch?
  6. CRNUT
    Feb 7, 2008
    8
    Because the switch can't be changed. Its built in...
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    This is 12V DC, right?
    Is the switch simply SPST, or does it have a center off position as well?
    See the attached - it uses a single diode in addition to your two bulbs and switch.
    The diode will have about an 0.7v drop across itself, leaving one bulb slightly less bright.
  8. CRNUT
    Feb 7, 2008
    8
    Correct 12V DC, with a center off.
    I want
    middle---nothing lit,
    bottom--one lit,
    top------both lit
    Two bulbs and preferably two basic 4-5 pin relays (automotive type)
  9. CRNUT
    Feb 7, 2008
    8
    I can control power or ground to the bulbs as well...
  10. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    No relays needed - just a diode. See the schematic in my last post.
  11. CRNUT
    Feb 7, 2008
    8
    I should be about to do the same thing as your diagram but replace the bulbs with the primary relay coils and I should be ok?
    I don't think the switch is rated to handle the bulbs thats why I wanted to use relays...
  12. nomurphy
    Aug 8, 2005
    567
    12
    Ummm, the 1N400x series is only good for 1 amp which may not be sufficient. Make sure the switch and the diode are rated at least 2x above the currrent of the lights.
    I = W/V
    2.1A = 25W/12V
  13. CRNUT
    Feb 7, 2008
    8
    Radioshack 276-1661???
  14. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Ahh, ok. I was thinking you were working on radio indicator lights or something.
    Sure, in the schematic I posted, just replace the lamps with the relay coils.
    You'll need two SPST relays in addition to the diode.
    Also, use diodes in reverse bias across the relay's coils to absorb the reverse EMF when the current is interrupted, otherwise your switch contacts will have a short lifespan due to arcing.
  15. CRNUT
    Feb 7, 2008
    8
    I am actually installing HID headlights on my four wheeler and trying to use the factory mounted switch built into the handle bar controls haha
  16. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Oh, OK! Yeah, the current draw of HID headlamps would've cooked the switch pretty quick!
