Rheostats & Potentiometers
Discussion in 'General Electronics Chat' started by PackratKing, Jul 30, 2015.
  1. PackratKing
    Jul 13, 2008
    850
    216
    Rheostat 1.jpg rheostat 2.jpg Some time ago, the Packrat snagged some older electronic gear from the local recycler... long story
    Among the " treasures " were a few larger {ruler} Clarostat pots, or wirewound rheostats may be more accurate. Being the eternal Novice, I was searching google for old Claro units, to little avail.
    I opened one up gingerly, and noted the wirewound resistance element, and wondered if anyone might know the wattage of something like this...
    This is much larger than some of the 2 watt units with a carbon element in my rat collection, ... so I was thinking at least 5 watts ?? the numbers on the can... top to bottom...11-36, 7.5K ohm, 140-6831
    What say Y'all ??
  2. #12
    Nov 30, 2010
    16,671
    7,319
    Here is a 2 watt Clairostat, so I think you're about right at 4 to 5 watts.
    Funny thing, they aren't rated as high as you might imagine from the size because the cooling capabilities were worse back then. Cast a jaundiced eye.
  3. strantor
    Oct 3, 2010
    4,302
    1,989
    Here's a 50w ohmite, circa 1993. It's only half an inch wider than yours. But it's open in the rear, for cooling I suppose. 20150730_195548.jpg
    PackratKing likes this.
  4. PackratKing
    Jul 13, 2008
    850
    216
    Hi Strantor...
    I have a few of these... although used, they appear in good shape... I have been toying with designs to build these using fire-clay, epoxy, and NiChrome windings... coil spacing remains a stumbling block, prior to final coating of epoxy insulation...
    Will likely use "Corona Dope " for insulation, tho I need to hi-pot materials to know which will stand the stress...
